lc-1 install pics
ryan george
i hope everyone had a merry and safe christmas. can someone pls post install pics on their lc-1...or direct me to where i can find a thread or link on this? i'm specifically looking for where you mounted the lc-1 under the car, where you ran it thru to get it into the car, and where and how you did the grounding. many thanks in advance!!!
i can help you with this. first thing is is the car a column shift or a floor shifter?
Here's mine. I used a piece of carbon fiber and two bosses that are on the hvac box. I ran the wires through the infamous speedo cable hole- I have an electric speedometer, so there's plenty of room. I grounded it to the stud above the gas pedal. Make sure when you wire the lc1 you use a relay to power it- sorta like a fuel pump hotwire setup. HTH.
Mark
