Leak down test
1NASTYGN
Performed leak test.
Yes sir. I will perform the leak down next. I’m getting some vapors from breathers and not sure if it’s the E85 or something else. Thank you gentlemen
Tested passenger side. Very little to no movement
Personally his compression number all look good
Leakdown test will tell you if its rings , valves or head gasket on a cylinder that is low compression
Yes 140-149 has some split but the plugs are rich fouled and that can cause some split
I truly have idea what a E85 plug should look like, but those don't look so good.
I would think E85 could wash the cylinder down if to rich and give you some vapors. Is my thinking wrong here?
You want it 100psi so that you are representing compression. That way you will get a "leak" through the rings, or a valve seat etc. At 30psi you re not even making enough to show squat. I am sure you tried it at 100psi yes?
if you have cometics and suspect a leak just hook the compressor direct to the cylinder (no leak down restictor) and listen for air
but cometics can get damaged and leak just a little and difficult to find without removing the head , except when they burn a track across the deck and the head
moisture in oil isnt new to e85 users , hook a catch can to the pcv and youll be surprised , i usually see 1/2 a cup or more water from a tank of e85 vs none when running 93
