leaking antifreezemy car
turbot2112
car has been leaking antifreeze.every once in a while ill see a tiny puddle under the car. not in the front of the car though, towards the back of the motor. i crawled under the car and saw a spot of antifreeze on the lower control arm. i dont hink its the heater core. maybe a headgasket:? were is the most common palce to blow a headgasket on these cars. only reason im thinking headgasket is because i put the motor together myself:D . its got about 25,000 on it. anybody tia:D
I would rent a coolant pressure tester from the local auto parts store. And see where leak is originating from.
Might even be as simple as a hose or clamp!
I'd bet it's your heater control valve. If it's original, it should be leaking by now. These are still available at GM.
It's where the heater hoses go into the heater core up near the blower motor area.
Should have a vacuum line going to it and one heater hose into it and one out of it. Small S or 90 degree hose pieces off the hard water lines next to the throttle body.
Not hard to find. :)
