Hello-
So I have a completely stock unmolested 2nd owner 1987 buick grand national with 90k miles on the drive-train. I took the drive-train out and freshened up the 200 4r BRF transmission thus far. Now my plan is to start focusing on "spring cleaning" the engine with new (valve stems, comp valve springs, melling oil pump kit, rear main seals, timing chain, 180 thermostat and a few other items. I've been told to NOT break the seals on the heads unless I have too...prior to taking out the drive train I got 150lbs PSI on every cylinder with the compression tester.
So, should I take out the stock iron heads and have them inspected at an engine lab and while they are out have them ported and polished and go with ARP bolts or should I leave them as is?
My goal is to run in the 11's quarter mile which I know I can accomplish with stock irons. I plan on upgrading the stock turbo to TE-44 down the road but for now I am going with the stock turbo/injectors and get the car running as it should before I start throwing money into after-market stuff..
Your advice and experience is greatly appreciated.
