After having tried many ways to adjust my Comp 885's, I tried it this way. I got the engine good and hot ( GN1 heads) and then used a .002 feeler guage to adjust them. When the feeler guage was good and snug, I turned the Scorpion adjusting nut slightly tighter. The lifters all sound the same now, just a slight noise. Just wiggling the rocker or pushrod up and down was still leaving enough play to get the .002 feeler in there. I also think adjusting the valves hot makes a difference. Normally, they would get tighter on iron heads. I think they may loosen up when hot with aluminum heads.
