Ok, so there is an article in GMhightechperformance about some mods to a TR at Cotton's. Very cool article but I digress.
So I bought the line lock they sell as it is the same one on the car. What can I say...I am driven by pictures
Anyway, it came with a pre-bent line from the brake to the control unit.
When I tried to install it I found a problem. To fit the line lock has to be where my fender relays are located. So...I tried to bend the line to make it fit better.
Now I need a new line
Some questions:
1) in the picture the line lock is installed in the line coming out of the rear of the master cylinder, closest to the firewall. I assume that is the one I use?
2) is there some kind of flexible line I can use to go from the master cylinder to the line lock? Something that will hold the pressure?
3) the article said "we carefully bent the stock line that was in the master cylinder". Is that ok to do or should I get more line and try to keep from bending it at much as possible?
Thanks for any input
Will
Some questions:
Will
