Line lock switch connection.
Bob Avellar
Not sure what might be the best way to mount the LL switch. I plan on using a Hurst button mounted on the stick, just below the shifter handle. My question is what is the best (neatest) way to run the wires up through the factory console? Is there room to somehow come up through the black sliding thingy that moves with the shifter? Open for suggestions. Pictures would be helpful. Thaks!
I drilled a little hole in the plastic and ran the wires up through there. Just make sure it doesn't contact the METAL bracketry down under. Just in case it did, I ran the power from a fused toggle, since I only used it at the track, That's when I would energize the LL.
