Line Pressure
Morkai
Morkai the Red
How do these main line pressures sound?
(min tv, max tv) rpm-idle(~800-900)
P 65 225
R 100 245
N 65 230
4 65 200
3 65 220
2 195 195
1 195 195
RUNNING AGAIN?
You got it up and running again? How is it shifting? Still have the trans go shift kit in it?
Brian:D
shifting..
Yeah, I put another pump in (10-vane) and all new red lined clutches. It's shifting pretty firm, not as violent at low throttle as before, but I'm only running a .300 rev boost valve now. Yes, transgo kit is still in it, actually the boost valves I went with in this pump are the transgo valves (.300&.500).
I've got a set of 245/60-15's on it now off (the front) of my camaro, and 2nd will bark them good part throttle and turn them over when you get into it. :D
