Little GN guidance needed
KCODE
The problem: My car set about 5 months due to a broken forward drum in the trans. I would start it twice a month. I just fixed the trans and put it back in. Before sitting the car was running perfect. Now it has a very noticeable miss. I drove it today and when I got to 16# boost it back fired. Scanmaster readings look normal.
My plan is: run out old fuel, change fuel filter, wires and plugs. My question is am I barking up the right tree or could it be something else. I've also recently put in a new ECM with powerlogger.
When you put the trans back in, are all the ground wires hooked back up?
If someone moved them to a trans bolt in the past, you might have left one hanging.
Would a bad ground cause it to run like I described?
A bad ground can make you want to soak the interior in diesel fuel and throw a match to it.
Make sure the ground is hooked up from the fire wall to bell housing on driver side.
Im thinking thats it b/c there was a spark under the car in that location.
Sent from my SCH-I800 using TurboBuick Mobile mobile app
One think i forgot to mention I changed the fuseable link. I was wondering if that coyulf cause my recent issues?
My first thing I would do is get rid of 6 month old gas as pump gas starts to lose octane after only 3 weeks?
Probably the gas is ok until you get too much boost, in your case 16 psi is past way too much.
I keep 110 octane leaded race fuel in my low mileage and not often used turbo cars as this fuel will last a couple years!
[QUOTE="Nick Micale, post: 3528228, member: 793”] pump gas starts to lose octane after only 3 weeks? [/QUOTE]
How much will this effect someone running ALKY?
D
D[/QUOTE]
Very good question, but I do not have an empirical answer?
Since gas has more octane than alky, I would surmise that it could have a dramatic affect after 6 months.
Hey Nick. Thinking of going his route.
QUESTION; How do you deal with wb sensor fouling?
Thanks for all the reponses. The black diva is running a ok at this time.
