Location of Fusible link
blckdrgn1987
11.78 @129
Greetings fellow gear heads
On my 87 GN when using any of the climate controls the fan works in all modes except High. If I am reading the manual there is a fusible link "A" that supplies the power fro "high". I am not sure where to look. Is it one of the five on the starter? Thanks in advance.
Geoff
Check the connector to the to the HVAC under the hood, the one with the red power wire. Wiggle it a little, sometimes that doesn't make good contact and will cause your problem.
