HighMileage
Albany,NY
Hey gang,
I've got no lockup but I'm getting the command as per my powerlogger.
This is a replacement tranny for the replacement tranny. The lockup worked in replacement #1. Unfortunately replacement #1 turned into a Slushbox after 100 miles or so.
The lockup hasn't worked in #2 since installation. Same converter as #1.
I'm gonna check the switches. Maybe they put the wrong ones in. I did notice that the plug on the 3rd gear switch was loose fitting.
I'm thinking of not plugging the 3rd gear switch in.
Are the switches supposed to ohm-out open or closed?
Thanks!
Thanks!
