For you guys running a fuel pressure sending unit on/near a stock fuel rail........to use for datalogging purposes..... where did you mount the sending unit.......and do you like the way it turned out?
It appears the only legit place is where the line comes into the fuel rail....
I thought about making a block to screw it into... and putting a low profile tee where the schrader valve is... and remote mounting the sending unit maybe under the intake plenum... kinda hidden.....or near where the EGR used to be...... running a short piece of small diameter hardline to the remote mounted block.... more difficult.... but probably more accurate.....and definately has a potential to be better looking....... I've just never seen one done that way.
