1dollardog
Are we there yet?
- Jan 5, 2007
Ok I have started a project that will probably take me a couple of years to complete (working on it in my spare time and with my spare money..). I've had the idea of a "rmts" type of turbo set up under a hot air for a while. For those who may not know what that is where the turbo or turbos are remotely mounted under the car in the stock muffler location and is plumbed accordingly. I'm planning on doing a twin set up using 2 stock hot air turbos. If I remember correctly that will give 120mm worth of turbo. Alot of what I have in mind is just that, in my mind. It may not be a science or even remotely possible so chime in with ideas if I say something off the wall. you won't hurt my feelings lol. And for the purests out there I definately wouldn't do this to my car if it was a perfect show car. It was mostly stock with a few minor upgrades (see signature).
What I have done so far:
I've removed the intake. I've ported it drilling into the "runners" opening it up as much as possible from the port side. I didn't have it totaly gutted. I didn't know anyone local that could cut it open and do what needed to be done and reseal it again. I want to do as much as I can "in house" and learn as I go. I have a spare back up incase I did something wrong and couldn't use the final product lol. I had a 90 made out of 2.5" exhaust pipe and I made a bracket and welded to it to bolt into the stock turbo mounting location. I had the 90 swelled to fit the hole pretty snug and for now in lew of welding it I sealed it with JB weld. I'll see how that holds up but for now with the bracket bolted in place and the JB, it seems solid as a rock. The 90 has a flange that the TB bolts right up to. The TB is almost in the stock location but sticks out about an inch more than stock in the direction of the master cyl. Throttle brackets and vacuum block all went back like before. I've removed the egr and plugged the egr hole and the threaded pipe end. I plan on having TT do a new tune on my chip and program this out. I'm just guessing that can be done. I removed the stock exhaust manifolds and replaced them with a set of Hooker headers. I drilled and tapped for the O2 sensor. I've had the muffler shop mate it back up with the mufflers. With the intake opened up some what and the exhaust free flowing it actually has noticable torque even without the turbo. I'm not driving it now, I just noticed that on the way back from the muffler shop. With the turbo and egr gone it gives the engine a pretty clean look too.
Whats next:
I've made mounting brackets for the turbos that will mount to the underside of the body between the fuel tank and rear end. The exhaust will feed in and out normally but I plan on using external wastegates instead of stock. The oil will be fed from the stock oil feed location and pumped back via a scavange pump. I may have to fab a resevoir for the oil to drain into that will be mounted under the turbos and then pumped back to the engine from there.
From here the psi air will feed back toward the engine via 2-2.5" pipes. This air will probably cool alot on the way back to the engine but I'll route them into a tt fmic then to the TB via a 3.5" pipe. I haven't quite figured out yet if a stock maf will take this or not.
There it is in a nut shell. I've left out many many details but that is pretty much what I'll be trying to do. As far as cost, like many of us I have many of these parts already laying around. The biggest costs for me will be the IC, wastegates, and scavange pump. I hope I don't get many of the "this will never work" comments but tell me what you think. I'd bet the first thing I here will be "why don't you just convert to the 86/87 set up". All I can say is that has been done to death.
Whats next:
