Thanks for the offer. Unfortunately, the wife has me booked up the next three weekends.
I did talk to Jeff yesterday, and it looks like we're trying to put something together for Memorial Day weekend, probably that Saturday. He thought we could do a "hang out/figure out why Mountain GN's car knocks" kind of deal.
And yes, I have a Scanmaster and Powerlogger. I'll even have a WB by then, though I'm not sure if I'll have it installed.
Thanks for the response, Lou.
I do have Julio's single nozzle system, through which I run 100% methanol. I spoke to him a while back, and he told me I need to tune the car to be able to hit 15 PSI with no KR before even trying the methanol. This has been the problem.
I do, for the most part, have the setup you recommend: Eric's TT Alky chip setup for 23/21, 50 lb injectors, and R43TS plugs. They are, however, gapped @ .035. Coilpack is about 3 years old, and I have a hot-wired Walbro 340 set to 43 PSI (line off). Fuel filter is new, too.
Car runs great, except that it starts to knock on the gauge at about 6-8 PSI with the default timing on Eric's chip. If I pull the max timing from the chip (about 9 degrees), I can eliminate most of it. I can run upwards of 22 PSI with no KR on methanol, but I have to max out the gain on alky system to do it, and even then, the car just doesn't feel that strong.
I've checked for vacuum leaks and can't find any. BLMs are in the low 130's, and about 130 at WOT.
I'm also fairly certain that it's not false knock, as it all goes away with lots of meth or race gas.
It's pretty frustrating!
