Looking for best 1350 pinion yoke
troyk
These are the models I found so far:
Strange U1594 u bolt-U1610
Inland PY10 u-bolt
Moser PY150 u bolt
Motive Gear MG1350-8550 ub
Motive Gear MG1350-8575 strap
Mark Williams 39003 39112?? 2nd gen u-bolt kit
From what I found, no one makes a yoke that takes a cap, just straps & u-bolts. Why is that? Which is stronger?
Mark Williams 39112, if it fits a 39003, looks like the strongest bolt I have found.
Also, I was trying to buy a DS & they want to know all the specs for the shaft, I assume I will not be able to spec this till the yoke & trans is installed, right? Dynotech is the DS I'll be buying & I was buying thru Full Throttle.
I assume a 3.5" steel DS is good enough?
My motor is out now, I think I'll b making 600wHP, but my Buick group seems to be pushing me for a 900hp turbo, so somewhere less than these 2 numbers.
250ci, gn1 alum heads no porting, alky, Cam??? 215/220 is probably be the biggest I'll go, but currently scheduled 212/212 roller.
Do yourself a favor and buy the strange chromoly shaft. Badass drive shaft for the price of steel.
