looking for Gasket installation advice
tzque
I am looking for some one to give me any gasket installation tricks to hold the gasket in place . I was told to use vaseline . ANy suggestions ? Overall I didnt set the car up high enough which has created one on my issues . I am a big guy
I assume you mean the valvebody/seperator plate gaskets. I use vaseline.
What gaskets?? Just use the Red Spray tack & stick them onto the part going on the motor?
grease
Vaseline works best--do not use grease--since this is in the trans section--I assume it pertains to VB or pan gasket. Vaseline will also hold check balls in assuming the trans is not hot.
