My 87 block is at the machinists, he says it looks like it needs nothing more than a cleaning and will get new bearings and rings. The camshaft is as new as well.
But.....
It is apart and with future mods in mind, what would be the recommendations to do at this time? I have been reading threads here and I am absolutely overwhelmed by the amount of mods for these engines. I have built a large number of v8's in my day, including several LS engines last few years.. I do my own assembly usually, this is the first shortblock I am having someone else put together.
Was looking for a beginners thread on mods but couldn't find one that applies to my situation. I have lurked for years and all the info is always great, but all a little advanced to the uninitiated.
My questions are this: if I keep stock pistons (they are in great condition), what camshaft should I go with? Should I have the machinist balance engine? He has recommended it and will do it on the cheap as we are well acquainted. I have 42lb injectors, an ecm extender chip(?), upgraded fuel pump and an aftermarket throttle body/plenum. Also have a LS1 MAF with translator. Have stock intercooler to use.
Just want to put together a strong motor for the future. Have no set goals on performance, but would like a starting point on the shortblock. More of a mind for a touring car than a drag car.
Will worry about heads after block is done, but they look like new.
Here is box of goodies and pic of MAF.
But.....
