I've got a fuel cell and A1000 pump on the way... and the Champion intake showed up today.
What I was "planning" to do is this...
Run one -08 line from the cell to the pump then one -08 from the pump to the pass side rail.
I'd like to use my old regulator I pulled off the stock rail setup. I threaded it to 1/4npt in/out, then installed -06 fittings in/out. I remote mounted it to the PS reservior bracket.
I was 'gonna adapt down from -08 to -06 at the driver side rail fitting and run a -06 line from the rail to the regulator, then -06 from the regulator to the cell.
I purposely didn't buy any fittings or braided line yet, just so I could see what fittings came in the Champion rails and what I had to work with.
My question is this...
Will a -08 pressure x -06 return system work OK with the small regulator that was made for the stock rail combined with the A1000 pump ? I was just concerned about the lack of return flow capability it has.
I also kicked around the idea of dual-feeding the rails, but really wasn't sure how to go about it while maintaining a clean engine compartment.
I also thought about doing it in -10 feed x -08 return, but the cell only jas a pair of -08 outlets... so I'd need to tee the two -08 outlets into a single -10 going to the pump. I'd also need to upgrade to a bigger regulator then too.
Any ideas ? suggestions ? pictures ???
