Looking for some roller cam reccomendations from the fast people!
BetMinesFaster
Turbo LSX Trader
Hey Guys, Im in the process of building a new stroker for the GN, Its going to be a .020 over 109 block stroker car, girdle, steel caps, 70GTQ, alky, maft pro, 83lb injectors, TA headers, GN1's, Champion Ported intake, 70mil tb with RJC doghouse and plate, and the typical goodies.
Im looking for suggestions on a roller cam that will add up to a nasty mean car, primarily street driven with a 3800ish stall, will see the track a few times a year.
Currently have a 218* Flat Tappet and am happy with that, but being an old gring im certain that there are better choices out there, Thanks in advance for the help, Ryan
If you want to get confused, this will help the situation. Everybody will pump up their own cam. Your best bet would be to call an expert. His info is in my sig. Give Dan at DLS a call, he will explain and make this transition for you seamless. He can sell you the cam and the hardware needed to put it all together. Anytime I call him I say, "Dan, hook me up". I explain my goals and he tells me what I need. Doesn't get easier then that. All the best.
Whichever cam you choose, be sure to address the cam gear wear issue up front to save some headache later.
http://www.turbobuick.com/forums/engine-tech/236335-cam-gear-cam-sensor-wear.html
http://www.turbobuick.com/forums/general-turbo-buick-tech/235269-cam-sensor-gear-wear.html
BOP Engineering Buick V8
I have a 210/210 comp roller. Easy off-the-shelf 10 sec cam with great street manners. Probably want more cam for 9's though.
Thanks for the links and info!! Ill be looking into all this! Ryan
