Another trick I used.
Jack stands under the frame, jack under the rear. Put the tire back on, 3 lugs hand tight is OK (don't forget later).
Lower the rear so the tire is just touching the ground. Roll the tire front/back to move the axle. You can roll the tire with one hand, and align/insert bolt with the other.
