Father's Day was taking my 18 year old daughter out to father's day dinner in GN and noticed engine was missing under very light acceleration
but once it gets into boost the miss goes away and runs normal:biggrin: a few minutes later I make a hard launch:biggrin: and look down at gauges (GNX Dash) a see 0 OIL PRESSURE
takes my feeble brain a couple of seconds to believe what I'm seeing and shut engine down and coast into parking lot. As I'm going thru what just happened I try to restart, crank engine over for 1-2 seconds...does not try to fire so I call AAA
. Engine has had really good oil pressure all the time, has fresh melling pump coated bearings and RJC deep pan. Did not hear any weird noises before I shut it down...no knocking or lifters ticking. Hoping cam sensor roll pin broke causing oil pump to quit and preventing timing sync for restart.....will check tomorrow.
What do you think
What do you think
