lots o parts , mafs, axles, posi, ck trans and more
pacecarta
LOGGED OUT
Staff member
front lower frame braces (kirban) ... 45 shipped
zo6 maf (5 pin 4") ....85 shipped
60# mototron injectors (from turbotweak) and Turbotweak 6.0 wideband chip (for alky ,66mm, ported heads .. its very tunable and auto correcting )....325 shipped
precision plenum (cast finish) with rjc power plate ....185
62mm steve monroe bored throttle body (has iac mtg, no sensors, or brackets ).. 125
............. or take them both 275 shipped
kirban billet fuel pressure regulator.... 85.00 shipped
caspers tps tec (for 86-87) ..... 50 shipped
casper iat extension harness 36"......... 25 shipped
reds volt booster with vac tee ..... 50 shipped
race ported iron heads from merkel- big valves , beehive springs , cut for orings ..850 shipped
LPW ultimate girdle cover with moser main cap stud kit... 175 shipped would cost 205 new
umi rear control arm kit ( black poly adjustable uppers, black poly box lowers ) look brand new... 250 shipped
lakewood front shocks ... 60 shipped
used air bag setup (2 bags, cusions, lines , fill nipples) 65 shipped
CK full billet 200-4r , ... 2200 +ship
tilt steering column for floor shift, burgundy w new cancelling cam and black key cylinder 165 shipped
ppal ok +3.5%
shipping included will be to lower 48 only
Paul can you send me a pic of the loop. If its the right one ill take it. Jeremy
PM sent
"casper iat extension harness 36"......... 25 shipped"
interested in the shocks, are the lakewood shocks adjustable street strip type or are they like a 90/10 drag shock, thanks in advance, rob
does the rear end upgrade come with c clip eliminators? how much is your best price shipped for whole rear upgrade set-up, thanks rob
rob lakewoods shocks are #40100 90/10 not adjustable (57ea +ship @ jegs)
the axles are c-clip (stock style ) ..
they dont have c-clip eliminators installed , these just slide in but could be used with moser 9200 clip elims --note unless you already have moser clip elims they arent a simple slide in and requires cutting back of the axle ends would also require cutting off the c-clip retainer buttons so the axles could never be used for clips style again ..
sending you a pm
sending you a PM
correction ---the umi rear uppers arent adjustable ---
heres a pic of the uppers and lowers .. its the umi 302116-B kit
as requested...pics
more pics
the sensor pipe includes the harness adapter to the translator and also has plug to connect the sensors IAT to the factory harness ,
MAF translator is version 6.25,
also has the 4" coupling and clamps to connect to the turbo ,
