LOTS OF PARTS, GARAGE CLEANING. LS, IC'ED, B4B, BRAKES, RJC, CAM, ATR EXHAUST, CASPERS, ETC
Ken Adams said:
Moog rear springs for $45 shipped to 65101? Will you accept MO for payment?
How about $50 even. MO works fine, I will PM you my address if it works for you.
Moog springs sold, Stage Right brake sold, RJC Powerplate sold.
Make an offer on rest!
Bump, want to clear out the rest of this stuff. Lots of brand new steering components, etc.
Adjusted prices, want this stuff out of my garage! Make offer if you don't like the prices. Don't want to spend $? Open to trades possibly.
BLAZER FRONT BRAKE ROTORS, COULD USE A TURN AND SPRAY JOB. STILL LOTS OF MEAT. $10
LARGE FLAT RATE BOX
VDO PYRO GAUGE AND SENDER $40
15 OZ 7X4X3
RJC PCV CHECK VALVE $20
3.2OZ ENV
OIL PUMP MISC: BRAND NEW TA PERF OIL PRESSURE REGULATOR, STOCK AND HV GEAR SETS, WEAR PLATE, SPACER, MISC SPRINGS FOR DIFF PRESSURES, BYPASS VALVE, BOLTS, FRONT COVER SEALS (NEW AND OLD STYLE, FUEL PUMP PLATE GASKETS, PICK UP TUBE GASKET, ETC, ETC $30
SMALL FLAT RATE
B4B DISTRIBUTOR $50 obo (PAID $50 FOR IT AT THE SALVAGE, PICKING IT UP FOR SOMEONE ELSE WHO WENT MIA. JUST WANT TO MAKE MY $ BACK)
7LBS 13X11X9
B4B QUADRAJET CARB $45 obo (SAME AS ABOVE, JUST WANT MY MONEY BACK PAID $50, SELL FOR $45?)
LARGE FLAT RATE
PAIR OF OUTER TIE ROD ENDS (NEW IN BOX, AUTOTECH MADE IN CANADA) $14
2LBS 7 OZ 9.5X3.5X2.5
BENDIX REAR BRAKE HOSE NEW IN BOX (HAVE 9 OF THEM) $6 each
5 OZ 8X4X1
SET OF ALL 3 BRAKE HOSES NEW IN BOX (2 FRONT, 1 REAR) set 1 $20
14 OZ ENV
SET OF ALL 3 BRAKE HOSES NEW IN BOX (2 FRONT, 1 REAR) set 2 $20
15OZ 9.5X3.5X2.5
PAIR NEW REAR WHEEL CYLINDERS pair 1 $12
2 LBS 3 OZ, 6X4.5X4
PAIR NEW REAR WHEEL CYLINDERS pair 2 $12
SMALL FLAT RATE
GOODYEAR LOWER RADIATOR HOSES NEW $10 (I HAVE 7)
I GUESS I CAN BEND IN HALF AND PUT IN A PADDED ENVELOPE?
2004 FORD EXCURSION FRONT AND REAR DURALAST GOLD BRAKE PADS, NEW IN BOX. PN DG757 (REAR) AND DG824 (FRONT) $30
MEDIUM FLAT RATE BOX
Adjusted prices, want this stuff out of my garage! Make offer if you don't like the prices. Don't want to spend $? Open to trades possibly.RJC PCV CHECK VALVE $20
3.2OZ ENV
7LBS 13X11X9
Offer $15 for the check valve and is the B4B distributor a vaccum advance unit or one of the later computer controlled units?
$15 plus shipping? Can prob ship it for around than $5, so how about $20 shipped?
Dist is vac advance. Buy it, will toss the RJC in the same box, and only charge $10 more for it. :)
Got tired of looking at these parts, most are on evilbay now... Let me know if you really want/need to dist though, and maybe we can work something out.
James
Have to check the rules for the SCTA class I'm doing a paper build for. If they'll allow me to run an aftermarket computer on a 7-pin HEI I'm going that way. Otherwise I'll have to run the vacuum unit and an MSD.
Will let you know when I find out from the rules committee.
