Lots Of Performance Parts
BLOWN526
Just Got The Call From Machine Shop And The Block Is Messed Up Where The Cam Had Been Walking So I Am Selling Everything That Is Left And Buying A Turnkey Motor
Champion Iron Cnc Heads With 130# Springs
Harland Sharp 1.55 Rockers
Billet Center Main Caps & Arp Studs
Reed 224 Flat Tappet Cam & Lifters & Timming Chain
Champion Intake With 83lb Injectors,70 Mm Throttle Body,egr Blockoff & Billet Thermostat Housing
Arp Head Studs
Stock Balancer
Stock Flywheel
Stock Front Cover With Waterpump
May Have Some Other Odds And Ends Like 5 Pistons Or A Crank That Needs To Be Turned To 30 Under
You Can Call If You Have Any Questions
My Name Is Johnny 803-206-6468
I Also Still Have The Modded Ecm For 83 Lb Injectors With Max Effort Me-r Chip With 16 Postion Thumbwheel And 3 Bar Map Sensor
Rjc Powerplate That Will Go With The Intake
Heated O2 With Caspers Wiring Harness
Send me a pic of the bad cam thrust and ill tell you if it can be fixed. Ive had them fixed them before.
Arp Head Studs
Stock Balancer
Stock Flywheel
How much? Please PM me
Interested in your champion iron cnc heads,and the harland sharp 1.55 rockers,also your champion intake with everything but the 83lb injectors.
Let me know a price shipped to 92064.
Thanks,
John
The Only Parts I Have Left Are The Heated O2 And Harness,flywheel,front Cover And Oil Pan
