Just Got The Call From Machine Shop And The Block Is Messed Up Where The Cam Had Been Walking So I Am Selling Everything That Is Left And Buying A Turnkey Motor
Champion Iron Cnc Heads With 130# Springs
Harland Sharp 1.55 Rockers
Billet Center Main Caps & Arp Studs
Reed 224 Flat Tappet Cam & Lifters & Timming Chain
Champion Intake With 83lb Injectors,70 Mm Throttle Body,egr Blockoff & Billet Thermostat Housing
Arp Head Studs
Stock Balancer
Stock Flywheel
Stock Front Cover With Waterpump
May Have Some Other Odds And Ends Like 5 Pistons Or A Crank That Needs To Be Turned To 30 Under
You Can Call If You Have Any Questions
My Name Is Johnny 803-206-6468
Arp Head Studs
Stock Balancer
Stock Flywheel
