Low alky light..
Steve V
Steve V's Automotive 757 560 2782
When does your low alky light come on? My tank is at the full mark and it comes one when I stab it and the car raises up. All the alky must go to the back of the bottle. That scares me:eek: 20=lbs of boost no alky =BOOM!
You mean full all the way to the top? Or full where it says cold? If its all the way to the top, there is no where for it to slosh ;)
Alcohol is 21% lighter than water. Nothing likes to float in it. More than likely the alcohol is sloshing in the tank cuasing the float to bob down. You spray 1 ounce per second, there is more than that sitting in the lines even under a very heavy launch. There is probably more than 3 ounces sitting in the lines.. enough to get you to the 330 :D
The fuel tank on the Buick is the same. When its on 1/4 tank and you leave hard the fuel goes to the back of the tank.. meaning you uncover the fuel pump pickup.. meaning you drop fuel pressure lean out the engine and BOOOOM like you said. :)
Non issue.. unless racing on empty tanks.
HTH
It's at the hot mark. I got the kit from a customer of mine,it's been sitting almost 2 years.
I run about 28 lbs on the street, I aint scared. Julio would not steer you wrong.
Bryan
Thats at half tank. Fill it up to the neck :)
That mark on the outside of the tank was put there by GM for when using Coolant. So you can disreguard any outside markings on the tank.
