Lowering Springs, 3.5" electric cutout with dump pipe, Neal Chance TH400 converter
murphster
  • Lowering Springs Brand new never used SPC rear springs from Savitske Classic & Custom and barely used Moog 5858 front springs. The SPC springs drop the rear about 1" from stock and the Moog springs drop the front about 1" from stock. $150
  • 3.5" Dump Pipe with 3.5" DMH electric cutout This is made for a 3.5" downpipe and will connect to a stock 4 bolt flange for the exhaust. You would have to buy the flange separately and have it welded to make one up. It is approximately 14" long. The wire casing had heated up next to the downpipe so I taped it up. I know the motor works fine but the wire may need to be repaired. $150
  • Neal Chance torque converter for TH400 This was in my White T until recently. I went low 10s at 131mph on my CPT70BB turbo. I was told it was a Neal Chance converter when I got it with my TH400 but I don't see any labels to confirm. Stall is probably around 3000-3200. Would be perfect with a 66-67 turbo I figure or even up to a 70. $300
