SignUp Now!Hello I would like to know if it is possible to pose a turbo LT-76 ON 109 block
the set-up is for my friend my friend has a champion iron headIts be done with some healthy ported heads.
the gn1 are you better ?The iron heads don't flow enough to support the 76MM Turbo IMO.
The 76 is huge for a 231 motor... dont need that turbo leave it for the bulldoizer's..... 45a is more than plenty of a turbo...the gn1 are you better ?![]()
It will work fine on a 109 with 3400+ stall and a t-brake. Overkill, but will definately work with the right tune.
half of the people say that they is too large and other half says that its ok![]()
