LT1, LS1 mass air, Ramcharger, Delco module, etc.
Eric Stauch
Nasty87
**Update** Removed parts that have been sold and lowered prices on existing parts.
Hey everyone, I am thinning out my spare parts collection. Let me know if you have any questions on anything.
Please contact me via PM as it is much easier to keep track of who is first in line!
PayPal is preferred but I will also accept a USPS money order.
If you choose to use PayPal please add the 3%
***All prices are SHIPPED!***
Thanks everyone!!!
1. New OEM Delco 85mm Mass air sensor. This item is new, and in excellent condition. $75.00
http://i628.photobucket.com/albums/uu9/thenasty87/0103131902_zps25a25360.jpg
2. New LT1 Mass air sensor. This item is also new and made by Richporter Technology. $50.00
http://i628.photobucket.com/albums/uu9/thenasty87/0103131905_zps14293f67.jpg
3. New type II coil set up. This coil and module combo is of borg warner brand. They are outstanding quality and I run this exact set up and brand on my car with zero problems. This is a plug and play set up, no cutting or splicing. You even use your original plug wires (they may move locations such as #4 plug wire may need to be swapped with say #2 just to adjust lengths.) This combo new is over two hundred fifty dollars! Parting with it for $135.00
http://i628.photobucket.com/albums/uu9/thenasty87/0103131903b_zpsf90f21fc.jpg
4. New Locksmart ignition switch. Replace that worn out 25+ year old worn out switch with a new crisp and better looking black tumbler set up! I run this switch in my car and I think the black suits the car much better than the factory chrome unit. $FREE! *WITH PURCHASE OF ANY ABOVE PART, FIRST BUYER WHO WANTS IT GETS IT.
http://i628.photobucket.com/albums/uu9/thenasty87/0103131906a_zpsfefbabd1.jpg
Ramcharger fans come with wiring or just the fan assembly???. Do they work from a stock Buick plug and come on automatically or do I need a wiring harness to make work.
Thanks tony
All prices do not include shipping unless otherwise noted!
Thanks everyone!!!
1. New OEM Delco 85mm Mass air sensor. This item is new, and in excellent condition. $100.00
2. New LS1 Mass air sensor. This item is new and made by Richporter Technology. It is an excellent unit and in my opinion an upgrade over a OEM delco unit. $85.00
http://i628.photobucket.com/albums/uu9/thenasty87/0103131904a_zps1ae5bc3a.jpg
3. New LT1 Mass air sensor. This item is also new and made by Richporter Technology. $70.00
4. New LT1 alternator upgrade. This is a new, not a reman, 140amp upgrade over the original GN alt. I have this exact unit on my 87GN and it works great. $85.00
http://i628.photobucket.com/albums/uu9/thenasty87/0103131903a_zpsb8df1877.jpg
5. New "Ramcharger" fans. These fans are new and made by the well known company VDO. This new fan setup is a much better choice than the hit or miss junkyard ones. $130
http://i628.photobucket.com/albums/uu9/thenasty87/0103131910_zpsed1266fb.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/0103131911_zps1f2b78d2.jpg
6. New type II coil set up. This coil and module combo is of borg warner brand. They are outstanding quality and I run this exact set up and brand on my car with zero problems. This is a plug and play set up, no cutting or splicing. You even use your original plug wires (they may move locations such as #4 plug wire may need to be swapped with say #2 just to adjust lengths.) This combo new is over two hundred fifty dollars! Parting with it for $175.00
7. New Delco ignition module. This is an OEM AC Delco unit. Never been used. These new go for nearly three hundred dollars! Giving it away at $190.00
http://i628.photobucket.com/albums/uu9/thenasty87/1114121832_zpse96d168d.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/0103131904_zps94166e85.jpg
8. New Dorman brand window switches. These are in excellent shape and they are getting hard to find with the bezels around them. $25.00 for the pair.
http://i628.photobucket.com/albums/uu9/thenasty87/0103131906_zps3970485e.jpg
9. New Locksmart ignition switch. Replace that worn out 25+ year old worn out switch with a new crisp and better looking black tumbler set up! I run this switch in my car and I think the black suits the car much better than the factory chrome unit. $10.00
I'll take the number "8".
Thanks tony
the fans come with all factory wiring and have no cut wires. They will require an adapter harness which you can pick up from a few different vendors. They are a great upgrade.
Alternator and window switches are sold.
sale pending on the ls1, and lt1 mass air and the delco ign module.
everything else still available. Make an offer! Thanks!
