Boostmeister
- Sep 22, 2001
I'd like to be able to bench test LT1 MAF's before connecting them with the translator just to weed out the duds. I apply 12 volts DC to the "C" terminal, ground to the "B" terminal. My output should be on "C". C appears to be an open-collector output, so I installed a 220k resistor from C to +3 volts. My output at C is now a negative pulse, 40 uS in width, at 288 Hz without air flow through the sensor. As I flow air through the MAF, the frequency increases. My questions are: is the C output really an open collector? What should the voltage to the pull-up resistor be, 5V, 6V, 12V?, and what should the correct resistannce for the pullup resistor be?
