LT1 Mass Air Flow Sensor
T-type Jones
23
8
3
56
I have the MAF translator and looking for an LT1 MAF, when I go to the parts store they need me to be more specific. I can give them a couple cars, makes and models they can pull out 2 or 3 that all look the same but the price range is crazy. Will any of them work or should I be looking at a certain one, if so give me a good year make and model that will good for my GN...THANKS
Turbo Keith
TURBO KEITH
Sep 16, 2015
1,488
373
83
New Albany , Ms
Ask for a 2010 ish Camero , something with a V8 , Do not ask for a Vette , The on I got from AZ for a camero was like 140$ and the same one listed under was damn near 400$ , Same exact MAF sensor , OR just buy from one of our vendors but AZ will have it on the shelf .
earlbrown
runs with scissors
May 26, 2001
7,062
1,274
113
48
lagrange, GA
The Vette ones are LS1s that are 3.5". You'd need a reducer coupling to put one of those on a 3" MAF pipe. (and most likely a larger, higher flowing air filter).
MikeS
85
22
8
I used the MAF from a 6.0 Silverado. Rock auto has them for $71, genuine AC Delco. You will have to buy adapters as it is 4", plus a 3 wire to 5 wire harness from Caspers. Altogether I think it was still under $100. It works great on my car with the standard MAF translator. From what I remember of doing research on this board, the 4" will flow a ton of air and has better idle characteristics then the Z06 MAF.
  • Like
Reactions: Turbo Keith
Top Bottom
