Aug 12, 2013 #1 N NOKA72 Member Joined May 27, 2001 Messages 602 Hey guys just installed an lt4 starter. It seems I need to shim it..a lot. Anyone else with this problem. I have a jw flex plate if that matters. Thanks VINNY
Aug 12, 2013 #2 precizion818 Well-Known Member Joined Nov 29, 2007 Messages 1,180 I am running LT4 stater and did not need any shims on mine
Aug 12, 2013 #3 Z ZNix Young-Gun Joined Jun 17, 2009 Messages 2,410 No shims here either! Stock bolts too! Sent from my SAMSUNG-SGH-I747 using TurboBuick Mobile mobile app
Aug 12, 2013 #4 H haywire4130 Active Member Joined Sep 11, 2010 Messages 664 Me three, bolted on with no shims, using a cat flexplate. Must be luck of the draw
Aug 12, 2013 #5 A azbob Member Joined May 23, 2008 Messages 444 I also did not use any shims and reused the stock bolts.
Aug 12, 2013 #6 N novaderrik Well-Known Member Joined May 12, 2004 Messages 8,076 are your bolts bent?
Aug 12, 2013 #7 H haywire4130 Active Member Joined Sep 11, 2010 Messages 664 novaderrik said: are your bolts bent? Click to expand... Good point, never thought of that! I used new gm ones for the vette.
Aug 13, 2013 #8 N NOKA72 Member Joined May 27, 2001 Messages 602 you know I should double check that if the bolts are bent....is there a spec as far as the clearance between the gear and flexplate....
Aug 13, 2013 #9 C CTX-SLPR Active Member Joined Feb 4, 2004 Messages 1,942 New bolts and no shims on my LT4 starter. No grindings either.
Aug 13, 2013 #10 N novaderrik Well-Known Member Joined May 12, 2004 Messages 8,076 NOKA72 said: you know I should double check that if the bolts are bent....is there a spec as far as the clearance between the gear and flexplate.... Click to expand... it's easy to tell if the bolts are bent- the starter wobbles as you take them out..
Aug 14, 2013 #11 Phoneguy Cometic HG stress tester Joined Aug 27, 2002 Messages 6,890 No shims here with a JW flexplate Bryan
Aug 14, 2013 #12 turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Messages 9,478 Cat flexplate...no shims
