Well, when I can´t find the inspiration to start with the car, maybe it will help me somehow to enter my track times from last year:
Details of the run:
60' = 1.958
330'
1/8 = 7.879
MPH = 95.75
1000'
1/4 = 12.137
MPH = 116.50
Lunkan, TTA# 1359
EMPTY WEIGHT: Stock (3630???)
BLOCK: Stock
HEADS: Stock
CAM: Stock
TRANSMISSION: Stock, with transbreak and shiftkit
TORQUE CONVERTER: Stock
DIFFERENTIAL: Stock
INTERCOOLER: Stock, without shroud
THROTTLE BODY: 62mm
RJC POWER PLATE: No
INJECTORS: Stock
THERMOSTAT: 160º
TURBOCHARGER: TA49
VALVE SPRINGS: Stock
MAF: Stock
DOWN PIPE: TH 3"
EXHAUST: Stock, with cut-out
FUEL PUMP: Walbro 340
FUEL PRESSURE REGULATOR: Adjustable
FUEL PRESSURE: Good question
ALCHOHOL INJECTION: No
PROPAIN INJECTION: No
NITROUS: No
AIR FILTER AND AIR INTAKE: JR Cone filter
TIRE DESIGN, SIZE & AIR PRESSURE: MT ET Streets 28*11.5-16
AIR BAG(s): No
SUSPENSION: Stock
SCAN TOOL: None
FUEL: VP Racefuels CSP
CHIP:
CHIP TIMING: ???
KNOCK RETARD: ???
OXYGEN SENSOR VOLTAGE: ???
EXHAUST GAS TEMPERATURE: ???
TRACK ELEVATION: ???
TEMPERATURE: ???
PEAK BOOST: 24 PSI
BOOST AT LAUNCH: 2 PSI
MILES ON THE CAR/ENGINE: 37k
The transmission was in a VERY bad shape:
- The driveband was just a small layer of coal
- All bushings was badly hurt
- The friction clutches was like crome plated
The TC was also badly hurt.
Details of the run:
60' = 1.958
330'
1/8 = 7.879
MPH = 95.75
1000'
1/4 = 12.137
MPH = 116.50
Lunkan, TTA# 1359
BLOCK: Stock
HEADS: Stock
CAM: Stock
DIFFERENTIAL: Stock
THROTTLE BODY: 62mm
RJC POWER PLATE: No
INJECTORS: Stock
THERMOSTAT: 160º
TURBOCHARGER: TA49
MAF: Stock
DOWN PIPE: TH 3"
NITROUS: No
AIR BAG(s): No
SUSPENSION: Stock
SCAN TOOL: None
CHIP:
CHIP TIMING: ???
KNOCK RETARD: ???
TEMPERATURE: ???
PEAK BOOST: 24 PSI
