dank GN
BlackArts Automotive (661)993-8277
- Jan 11, 2009
I just received my ARP M&A head bolts . I will be using these heads on the my 109 block then will transfer them over to my 14 bolt stage block ASAP . I have ARP studs on my 109 and they all would be useable except for the upper middle 2 . I'm thinking of replacing these 2 studs with bolts . Im worried about the 2 different clamping forces and compromising the gasket seal . So should I just use all new bolts or replace the center 2 ?
