I gotcha. So under WOT the standard chip type ignores all sensors and just runs its program with the MAF pegged at 255. It's up to the user to set the boost, fuel, timing, alky, etc to obtain the proper A/F ratio with zero knock if the chip has that adjustability (which TT does). Makes sense to me.
So wouldn't the best option be a setup where the MAF sensor and computer could read a HUGE amount of air flow along with a wideband communicating back to the computer as a secondary check? Wouldn't this yield the best drivability and performance with the least amount of tuning? The only problem I see with this is when the alky injection kicks in. For it to work the computer would have to control that as well.
