Cheeseburger
- Jan 25, 2004
I need to find the maf sensor middle wire at the ecm pin outs.
I no longer have the connector under the hood and need the proper pin out to have a jumper wire from the middle wire on the map sensor to the middle wire on the maf at the ecm.
I read b6 yellow wire, but my b6 is not the yellow wire b7 is yellow with a black stripe.
TIA.
P.S. if someone could check the colour code at the middle wire at the maf sensor that would be great.
TIA.
