Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Try this link.
http://www.turbobuick.com/forums/showthread.php?t=126494
SignUp Now!Thanks for the links. I wonder if its ok to spray alcohol :biggrin: through the MAF?Jerryl said:Stumbled onto this ....... one more link
http://www.gnttype.org/techarea/engine/mafrelocate.html
Ya your right. But I can here the old lady nowRosewood T-Type said:NO!!! MAF uses an element similar to a lightbulb it glows orange when operating.
I ran this same setup last year it seemed to have no downside. The car had much better throttle response. The reason i took it out was i wanted to run NOS then decided to go w/ F.A.S.T. so no more MAF.
My opinion go for it it's great, or go w/ F.A.S.T sell MAF, trans+,modded ecm,chip. your more than half way to used F.A.S.T. 1100.00 - 1200.00 and never look back.
Rick87GN said:I got to technical to quick, see the problem is that when built up air pressure comes back through the MAF read's it and surges gas making the car stumble. This happens when let off the gas. I turned of the DFCO feature on the extender (Delayed Fuel Cut off) that helped alot but still slighty there. The LS1 MAF works too good. I thought if I take it out of the path of that air relieving back out the system, I could get rid of the problem.
It seems the best way is to relocate the MAF since it's free.SloGN said:the best way to deal with that problem is to install a blow-off valve on the side of the up pipe tot he throttle body.
Rick87GN said:Relocated LS1 MAF in up pipe off my front mount IC.
I chose to locate it down behind the radiator to leave room room for alcohol.
This worked out very well. Got rid of the fuel surging from back preasure.
Throttle response improved my blm's 127-129 but most of the time 128!
Runs Awsome! This was a quick easy fix that is showing other positive affects.
Thanks for everyones help.![]()
