Mar 21, 2010 #1 A Aegis Member Joined May 2, 2009 Messages 46 I just bought a used maf translator and it did not come with instructions. I am using a 3.5 inch ls1 maf. Does anyone know what the starting setting should be for the 4 white switches?
Mar 21, 2010 #2 E Eric Stage I TurboTweak Guy Joined May 25, 2001 Messages 2,677 For a TT chip: ON,ON,ON,OFF in that order, MAF Base "0", MAF Wot "0" Eric
Mar 22, 2010 #3 A Aegis Member Joined May 2, 2009 Messages 46 Ok I have the settings on,on,on,off and the car idles fine, but when I get in the gas it sputters and then accelerates? Any ideas?
Mar 22, 2010 #4 A Aegis Member Joined May 2, 2009 Messages 46 Also the check engine light is now on????
Mar 22, 2010 #5 E Eric Stage I TurboTweak Guy Joined May 25, 2001 Messages 2,677 Check to see what code you're getting. My guess is code 34 (no maf signal).
Mar 22, 2010 #6 A Aegis Member Joined May 2, 2009 Messages 46 Thats correct I am getting a 34 code. The connector from the car doesnt seem to be fitting correctley into the translator harness. Ideas????
Mar 22, 2010 #7 T TurboBob Resident mad scientist Staff member Joined May 24, 2001 Messages 6,679 how many gray knobs in the translator? You may need an adapter harness, does the plug for the vehicle not fit "at all" or just not well? Bob
