So i spoke to the boys at Magnafuel and i got some more information that i wanted to bring up on this conversation.
chasmat and lazaris, you guys are running the 625 pump, which is a transverse mounted gear pump. this pump does not have fuel running through the pump to cool the motor, instead it use AIR to cool to pump. Air as we know will not cool as good as a liquid can, and thus is not recommended for prolonged use. The benifit is that is will not heat up the fuel nearly as much as the inline PROTUNER pump that Magnafuel offers (MP-4301, 02, 03) 1000, 1500, 2000hp Respectively.
Both styles of pumps must run on 12.5V or more, so a step down is a no no.
So the option is this, run a inline fuel pump, and have a fuel cooler  setup inline to cool the fuel so you are not increasing the overall temperature of the fuel as it is being circulated through the system.
What does everyone feel about fuel coolers. the only ones i have found are the ones at summit, but they are only -6 and i was hoping to use -8  for a return.
Also where should a fuel cooler be mounted if you can have one with a large enought inside diameter, Pre injectors, or on the return line??
I do not want to comprimise anything with this car, thus my anal-like questions and problems.
Thanks Boys.
Adrian
