Underboost
Mr. Dull
- Oct 4, 2005
hey guys,
well i am running a champion race intake and rails as well, i plan on running a -8 or -10 return. i know it is overkill.. whatever.
GNVYUS, you are are saying that i can stick to my Kenne Belle regulator?
Well lets run some numbers, does anyone know what a double pumper flows at 70psi. The Magnafuel states that at 12.5V, 70 PSI, it flows 1.5Gal/min
So what does a double pumper run? if it is similar, and people can run there normal regulators with the doubles, then this should be no problem. Right?
I had the Accufab/Kenne Bell "same thing" reg with a Red Armstrong Dbl Pump and the car ran 10.12 @ 134 on one of the pumps. I didn't have the second pump hooked up to the hob switch yet.
		 :biggrin:
 :biggrin:
