I talked to BG they don't recommend the bg5000 filter for fuel injected engines.  The filter will tear collapse inside at high psi.  The magnafuel mp-4701 pumps are not recommended for more than 30 minutes use, and will overheat.
The Magnafuel pumps can be run at short periods of time at 16 Volts no problem, but no less than 12.5.
The mp-4301 pump will flow 1.5 gal/min @12.5 volts@70 psi.
