It's been in a 1974 Toyota pickup. It went 7.60 in the 1/8th at 95 mph with a 150 shot of nitrous. I pulled it apart because of metal in the oil filter after the last time I ran it. It was mostly from the #3 TA cam bearing. I have a CAT 3.625 crank and H beam rods, JE custom pistons with file fit rings for a 9.75-1 compression ratio. It has a custom Comp roller cam 226 I-228 E, 108 LSA with 526 lift at the valve. Rollmaster chain, Comp 885 lifters, Champion GN1 heads with Scorpion 1.65 rockers, a Kenne Bell ported intake, and a 600 CFM Edelbrock carb. I built the headers after the old Kenne Bell 3 into 1 design. Jim Bell gave me the dimensions. MSD digital 6 ignition with a retard when the nitrous hits and a rev limiter, an NOS progressive nitrous controller, and a dedicated fuel system just for the fuel solenoid. The trans is a V8 Turbo 350 with JW clutches, TCI shift kit, and a JW 3400 stall converter. There is also a Gear Vendors overdrive on it. The rear end is a Ford Maverick 8" with 3.80 gears, a Detroit locker, and Curry axles. I run MT Street radials at the track and pretty much slip and slide. My 60 foot has never been under 2.00. I am afraid to run slicks with an 8" rear. I bought this truck new and swapped a 75 odd fire into it 2 years later. It's had 3, 3.8's in it, but this 4.1 stroker beats them all. I put a 3.8 back in it while I am rebuilding the stroker, and it feels like mush. Same cam grind but flat tappet, with ported heads, big intake valves and T&D rockers with a KB intake and 500 CFM Edelbrock carb. I can't wait to get the stroker back in it.
