OK, laugh if you must. I should know the answer to this but I don't, and for the life of me, can't find the answer in any of my reference materials.
Anyway, after sitting bare for 15 years, I'm going to slowly start putting my numbers matching engine back together.
I'm going to try and re-use all the original parts as much as I can (except the cam and lifters of course).
Anyway, here's my question. I dug out the old main bearings (don't worry, I'm not re-using any bearings) to see how they came fitted and mounted from the factory. A couple of the uppers were labeled .001 so it's important for me to figure out what position they were in. One of them is the one with the "partial" groove not covering the entire length of that piece.
I'm thinking it must be the #4 position, because it's REALLY obvious which one came out of the #1 pos. It has a LARGE black imprint on the back caused by the larger oil hole in the number one web.
And of course it's obvious which is the thrust bearing.
And why would the only one's marked .001 u.s. be the uppers???
TIA
TIA
