Red Regal T
Senior Member
- May 24, 2001
A used 87 109 normally aspirated standard long block. Includes 109 Block, just needs turbo oil return boss drilled to make it a turbo 109 block, Standard/Standard NA crank (rolled fillets on Main journals; can be used for turbo application), stock rods and 3.8 heads, same as turbo motor, timing chain cover and flex plate, never drag raced :biggrin: $350 U-PIK-UP!
