mal. code 45
black-gn
when i'm driving i can not get over 65 mph without black smoke coming out the tail pipe and the code 45 pop up on my scanmaster plus, my O2 volt running close to 900. can anyone tell me what code 45 is? :cool:
CODE 45
Trouble Code 45 indicates that the O2 sensor is showing a persistently low exhaust oxygen content (rich), despite the efforts of the ECM to decrease injector on-time (thus decreasing fuel delivered). Integrator and BLM numbers may indicate < 128 by a substantial margin.
The conditions for setting this code are:
no Code 34 or Code 35 (MAF error) present, and
the O2 sensor voltage remains above 752 mV, and
the ECM is in Closed Loop control, and
throttle position is < 2 percent or > 20 percent, and
the above conditions exist for more than 20 seconds.
Typical causes for this code include:
1) O2 sensor defective or contaminated (if incorrect RTV sealant or too much RTV is used, this may happen)
2) Leaking fuel injectors
3) Fuel pressure too high
4) EMI interference from poor plug wires
5) Evaporative Emission system defect
6) TPS and/or EGR problem
7) MAF sensor reading higher airflow than is actually present
