Manual boost control install ??
87WE4BOOSTED
I NEED MORE BOOST!!
Can somone please tell me which side of the boost controller goes to the compressor? Please note there is an arrow on one side of the controller. I have the PW46 ext wastesgate and will attempt to run it in "bleeded valve" mode.
Steve
Turbo compressor fitting....piece of hose...boost controller...piece of hose....waste gate. Zip tie all hose connections.
Your arrow points towards the waste gate.
Coach you were still correct about the arrow pointing towards the wastegate. And i should have said external and not ext...sorry.
Hey Mark, are you seeing 1psi per full turn on the controller?
Thanks guys,
Steve
