Apr 2, 2014 #1 K KCODE Member Joined Aug 1, 2012 Messages 229 i installing a razor alky kit. I go to area where map sensor is suppose to be a find this weird bluish green thing with hose attached. Also MAP sensor pig tail is unplugged? Is this normal ' 86 with digital dash.
Apr 2, 2014 #2 N notacarlo eggs are liquid chicken Joined Jan 7, 2004 Messages 7,493 That's a Hobbs switch for the two boost lights on your dash. Factory. currently cutting it the F loose
Apr 2, 2014 #3 N notacarlo eggs are liquid chicken Joined Jan 7, 2004 Messages 7,493 T off of that if you want the lights to work. Install the 3 bar somewhere in that vicinity and continue with the alky kit. currently cutting it the F loose
Apr 2, 2014 #6 K KCODE Member Joined Aug 1, 2012 Messages 229 Yeah I was getting through the parts I could do . The dash stuff is where I'll need help .
Apr 2, 2014 #7 R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Messages 13,391 You'll notice the 2 screw holes behind that sensor. Don't use the factory plug below it, use the harness supplied with the kit.
Apr 2, 2014 #8 K KCODE Member Joined Aug 1, 2012 Messages 229 Thanks I see them. Rgr that on the wires that came with the kit .
