Hi All,
It has been a while. I was installing a new adjustable TV bracket and decided to do a pressure test.
at 1500 rpm, my pressures look normal. At full TV, All my pressures seem to max out at 200 PSI. I remember reading 240 the first time I installed the trans.
Also, but this is probably normal when cruising my PS drops 50 PSI once the trans is hot.
Dropped the pan - the oil looks fine and smell grrrrreat as the tiger said.
One last thing, my last race I did find a loose bolt in the VB. Shifter side the last one in the rear. It was losing pressure there. I am guessing the leak might have affected the gasket which I am going to replace.
Thanks fer any thoughts,
D
D
