83lb injectors
car smells rich, slight change in idle 50-75rpm
codes 23,41,54
TPS .44
lv8 31-43
MAF 7 g\s
IAC 6
Battery 13.5-13.9
mat 95-97
Knock rtd 0 to 3 degrees
knock cnt 0-2
a\f ratio 2.6:1 to 14.4:1
o2 volts 761-765
o2 x cnt 0-2
Int 128-130
BLM 128-130
Fuel Pressure 42 hose off
Map on direct scan stuck on 118 (grid in middle)
All this was between idle 875 to 2400 Rpm.
Anyone have any ideas?
codes 23,41,54
TPS .44
lv8 31-43
MAF 7 g\s
IAC 6
Battery 13.5-13.9
mat 95-97
knock cnt 0-2
o2 volts 761-765
o2 x cnt 0-2
Int 128-130
BLM 128-130
