SignUp Now!------------------------------------------terryjh6 said:right now i seem to stop at 21 psi on my turbo is this the max on my stock actuator? do i need a hd actuator to go higher? and what psi will my stock turbo stop making boost? 25,30,35? anybody know? thanks terry![]()
---------------------bdeliman said:If you remove a piece of the rod in the middle, you can tap the ends and insert a turn buckle. This will enable you to shorten the overall length of the rod and increase the boost.
Rasing boost by shortening the actuator rod is not a good way to reach your goal. If you choose to use this method with the stock actuator,you'll probably reach 20-22 lbs. There are two problems this method will create. The first one is that since there is more force trying to keep the wastegate closed,it will not be able to open as far. The second problem is that it will not be able to open as fast.There are two situations that will call for the wastegate needing to open farther. The first is during a shift,when the motor suddenly slows down. When this happens,your motor has an instant need for less air to maintain any given amount of boost. If the wastegate can't open farther during this time, the boost will spike. The secound situation that will call for the wastegate opening farther happens at the upper end of third gear. In this situation,the motor will be producing more exhaust energy.If the wastegate isn't allowed to open farther during this event,the turbine will spin faster causing the boost to climb.The situation that calls for the wastegate to open faster is,the above,situation one. Since the event that happens during a shift happens so suddenly,the wastegate needs to open just as suddenly to to keep the boost from spiking. When you increace boost by shortening the actuator rod,you inhibit the wastegates ability to open farther and faster when it needs to. The way you control your boost solves both problems. Since your boost controller is only letting pressure act on the actuator when needed,You don't need to adjust the actuator to increase boost and,in fact you'll want to lossen it up as much as possible. This will allow the wastegate to open farther and faster when it needs to. Your boost won't spike or creep. With your controller,you don't need to adjust the rod for more boost, You simply adjust the controller if you want to produce more than 20 lb. of boost.terryjh6 said:i'm using a rjc boost control and have not needed to use the adj. rod on my accuator. I can dial in anything from zero to 21 psi w/ my controller. I was under impression that the stock accuator is only good to around 20ish psi, and anything over that would require an HD accuator. I thought that the adjustable rod was used on boost control solienoids like the stock set up. Therefore, I need to know is 21 psi, like I'm running now, is that the limit of my stock accuator? Thanks, Terry
Before doing this,disconnect the hose from the actuator and plug it. With your eye on the boost guage,gradually open the throttle and see if it will easily make boost beond 21lbs. If it does,do as Quick6'n'-K.C. advises. If it doesn't make any more boost than it does now,you have other problems.Quick6'n'-K.C. said:Stretch the spring on your RJC controller to get more boost out of it
BW
